Yealink T54W Call forwarding treats line as busy
green5
Using the Yealink T54W as the main receptionist. For incoming external calls, the phone appears as busy in the call log, even if it isn't off-hook, and forwards the call to the ring group. This was working fine before upgrade to V20. Any thoughts?
What is doing the forward? The user/extension is set to forward if no answer?
Have you powered it off?
Yes, the user call forwarding is set to a group. It immediately forwards to the group showing 0 ring time on the user phone and the following reason: Busy, forwarded to RG Windstar (800)
Can it dial out? *777?
I might just factory reset and reprovision.
yes and the phone shows as registered.
Finatra.us
