Yealink T54W daylight saving time settings for Poland are empty
Papajek
SOHO User
Hello
Just a simple bug report
Daylight savings time settings are empty for Polish timezone and we have to manually set out phones to Czechia
Nothing was changed in the template
This issue persists since last 3 firmware updates
Model: Yealink T54W
Firmware: 3CX 96.86.0.81
System version: 20.0 Update 2 (Build 715)
Hi Papajek,
Thanks for reporting, however this should be directed to Yealink Support since they are the ones that maintain the firmware and DST parameters.
DARRENJ
