Yealink T54W - disable wifi from template
itops-care-bears
hi team,
I've been trying to disable the wifi feature on this phone via template and need some guidance. I edited the template (copy from default template, edit the file and save) and selected the new custom template when provisioning phones. I tried the following values but none seemed to work - the phone always have wifi enabled.
static.wifi.enable = 0
static.wifi.enable = "0"
wifi.enable = 0
wifi.enable = "0"
static.wifi.1.enable = 0
static.wifi.1.enable = "0"
wifi.1.enable = 0
wifi.1.enable = "0"
Is there a way to disable the wifi function from 3CX console using templates?
PS. bw.feature_key_sync = 1
No, we do not provide any way for controlling WiFi and we do not support the phones being used in WiFi mode.
You will notice that our default template does not provision any values for WiFi.
If you were not successful via custom templates then you might have to ask more details on the Yealink forum, or look at the Yealink Administrator guide.
I managed to disable wifi from the template eventually. admin guide helped. thanks @JohnS_3CX
Reactions: JohnS_3CX
Finatra.us
