Yealink T55A Teams & SIP
ITCBS
I am looking at purchasing some Yealink T55A IP Phones and wondering if I can configure them to use as Teams as well as Connect as a normal extension Under 3CX
or
Can I just use it as a Standard SIP Phone?
The Teams Function is not that big a thing if it can work like in a Hybrid setup, I more want them just to connect to 3CX as a normal IP Phone
Thanks, Adam
The T55A is not supported. If your main concern is 3CX get something that is supported instead:
https://www.3cx.com/sip-phones/
By the way, 3CX offers Teams integration, so you should take a look and see what that offers you before making a decision. Perhaps there is a way that can serve most if not all your purposes.
https://www.3cx.com/phone-system/microsoft-teams/
DejanMDS
