Solved Yealink W60B - Only the first handset/extension is ringing
jst2
I am having a strange problem with my Yealink W60B. I have two handsets for it, but only the first handset is ringing. Here is what I have tried so far:
- Confirmed ring volume is on for all handsets
- Confirmed extension numbers of handsets match extension numbers in 3CX cloud
- Confirmed that Ring Group is set to "Ring All" and shows desired extensions as users
Everything looks good, but yet only one handset is ringing. What am I missing?
Hi, how many deskphones do you have provisioned? Only the dect with two handsets?
Is this provisioned with a router phone or dedicated SBC?
As first step check that both the base and handset are using the supported firmware available here
Thank you for your response!
My firmware version is "77.85.0.25" which is the one listed as recommended for 3CX.
The phone is provisioned by a dedicated SBC and there are no other phones at the moment.
it looks like an issue on the device, I may suggest you to perform a factory reset to both the Base and Handsets and reprovisioning again.
The factory reset has fixed the issue. Thank you very much!
Now, I only need to figure why the handsets can no longer call their voice mailbox. This has only become an issue after doing the factory reset.
I am going to create a new post for the new issue. Thank you again for solving this one.
Finatra.us
