Yealink W70B
havelkar
Hi.
I have new Yealink W70B with handset W73P.
Handset is sucesfully paired on base, base I see on 3CX, but i can´t set type from list on phone provisioning.
I folowed instructruction on https://www.3cx.com/sip-phones/yealink-dect-phones/ - no effect.
3CX version is 18.0 (Build 939), Firmware DECT is 146.85.0.40.
Please help me.
Greetings.
R.H.
The base is configured under Dashboard>>Advanced<<FXS/DECT:
In the configuration you first add the extension numbers and after the base is provisioned you register the handsets.
Nice, my mistake... Thanks.
But, what now?
On manual (step 3) says "Add a Yealink DECT phone in 3CX", but i haven´t Voice and Chat menu...
In the step 3 you see the provisioning steps if you proceed from the 3CX Web Client when accessing using the credentials of the owner of the key. This the same step if you add the Base from the management console.
OK, but on 3CX management console I havent W73H handset...
Just to clarify, the connection is between the 3CX PBX and the Base.
Once the base is provisioned it will get all the information that you have assigned in the configuration. Then once it is provisioned you will register the handsets to the Base. For PBX we do not provision the handset directly.
Yes, I understand.
But my base not provisioned anything on PBX. Maybe because I don´t know, where set provisioning settings on manual - step 3 on base.
Yes, this manual not working for me, but i solved...
For Yealink W70B base with W73P:
1) update Firmware on base
2) register handset on base
3) create FXS on PBX and set extension
4) copy provisioning link from PBX
5) on base go to Settings - Autoprovisioning - URL (paste link)
6) reboot base!!!
Thanks for your time and hepl.
R.H.
Glad to know!!
SupportRock
