Yealink WH62 issue on mac
cchenri
Hi everyone,
i updated yesterday to 18.0 Build 955 (update 4)
i noticed a problem with my yealink WH62 headset
My config :
3CX Desktop App. V 18.9.921. on Mac OS
there is an error when i select Yealink on the Headset integration
Error invoking remote method 'yealink': ReferenceError: Cannot access 'log' before initialization
any clue ?
thanks in advance for any help :)
Could be a permissions thing. Check access for the program.
Hi @kieferschild
i gave full access to the hard drive to the 3cx desktop app to check and rebooted but didn't change anything
What about for the Yealink software?
What if you use the web client only?
@kieferschild excellent idea, and it works
i don't like this version but anyway i'll stick to it until there is a fix for the desktop version
thanks again !
Try installing the PWA version again from the web client.
Same here i have the same issue with the desktop Mac Software and the Yealink USB Connect. - Webclient is working, but i don´t like it either :/ -
Does the headset work with Teams? It may be best to submit a ticket to Yealink.
@stefanprasch did you do the same mistake to update to 18.0 Build 955 (update 4) ?
i'm pretty sure it's related
I'm having the same issue, 3CX Client on macOS. Yealink headset integration stopped working after updating to the update 4 client,
SupportRock
