Zendesk Filtering which user is active
robert.taylor
Gold Partner
Hi .. new to all this integration stuff so please bear with me.
I have setup and tested the integration and it appears to work ok. Now i want to filter which users it is active for. It looks like i can do it by email ?
<Rules>
<Rule Type="Equals" Ethalon="[email protected]">users.email</Rule>
</Rules>
but can i do it by for instance the user group the user is in or the Call Queue the call originally was presented to or even the number that was dialled ?
<Rules>
</Rules>
What you want to do is just not possible. During lookup, you do not have any info about the user.
Also, you'd need to modify the template heavily, which I would not recommend if you are not sure of what you are doing.
Reactions: edossantos
This will not work as this is not part of the lookup mechanism and requires customization of the template which is not supported from 3CX.
LVCC_Admin
