Zendesk server side integration after upgrading to V18
jkampwerth
So I have followed the new guide of setting up zendesk - 3cx integration to the letter. For some reason, call journaling is not creating a ticket after the call ends but a new contact is created.
The template has not been changed. Can someone please assist?
Thank you
Are you on the latest v18? 18.0.3? There was a bug in Update 2.
Reactions: jkampwerth
Well that may explain it. We are on v18 update 2. We will move to update 3 when we can.
I can't believe I couldn't find this anywhere else.
Thank you!!
Thank you!!
It was a known bug and Update 3 was released last week so it happens :) It should fix your issue.
Hi, after moving to update 3, ticket creation is still not working.
Not sure what to do next. Any help is appreciated.
In order to investigate the issue, please enable verbose logs from the 3CX Console > Dashboard > Activity Log > Settings. Then make a test call where you reproduce the issue, and check the 3cxSystemService.log file that you can download from the 3CX Console > Dashboard > Activity Log > Logs button > Instance folder.
johnkerr995
