ZOHO CRM Integration Error
tech2go
Hi I'm getting this error
Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason= - Content={"code":"INVALID_QUERY","details":{"reason":"the field is not available for search","api_name":"Home_Phone"},"message":"invalid query formed","status":"error"}
Started scenario with empty id
Started Auth
Request text: https://accounts.zoho.com/oauth/v2/token
Request form value refresh_token set to 1000.695af5d5b0d8aea746d213e9fe212293.37e8039ea752bc48d944424d446e19a0
Request form value grant_type set to refresh_token
Request form value client_id set to 1000.KRUDIAYB74U695354V2UA0VVQHQTQH
Request form value client_secret set to 5fa969320af4b36dc166036d1b40f2996adb5400dd
Response text: {"access_token":"1000.3dceb4458b40fc1cf102b22682fdb8b4.20bcf8b22455aa304581341f4253f72f","expires_in_sec":3600,"api_domain":"https://www.zohoapis.com","token_type":"Bearer","expires_in":3600000}
Response finished
Variable AccessToken set to 1000.3dceb4458b40fc1cf102b22682fdb8b4.20bcf8b22455aa304581341f4253f72f
Variable ApiDomain set to https://www.zohoapis.com
Finished Auth
Request text: https://www.zohoapis.com/crm/v2/Contacts/search?criteria=((Phone:equals:551234) or (Mobile:equals:551234) or (Home_Phone:equals:551234) or (Other_Phone:equals:551234) or (Fax:equals:551234))&fields=Account_Name,id,First_Name,Last_Name,Phone,Mobile,Home_Phone,Asst_Phone,Other_Phone,Email,Fax
System.Exception: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason= - Content={"code":"INVALID_QUERY","details":{"reason":"the field is not available for search","api_name":"Home_Phone"},"message":"invalid query formed","status":"error"}
at CrmIntegration.ScenarioProcessorBase.ProcessRequest(ScenarioRequest request, IValueManager customManager, HttpClient client, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.ProcessScenario(ProtocolScenario scenario, IValueManager customManager, CancellationToken token)
at CrmIntegration.ScenarioProcessorBase.Execute(ProtocolScenario scenario, CancellationToken token)
at CrmIntegration.CrmProcessor.GetContactInfoFromCrm(String contactNumber, String destinationEmail, Boolean createIfNotFound, CancellationToken token)
Found a solution in previous thread -----
"Regarding the error you get, the problem is that the field "Home_Phone" is hidden for entity Contacts. You need to make it visible in Zoho, and the issue should be fixed."
But don't how to do it in zoho, please help. Thanks
skander
