ZOHO CRM Sync CDR Record
mismail
Dear,
I have done the integration with Zoho successfully but I have some notes :
- I can't listen and play recorded calls from Zoho! is that possible to listen to call and play from Zoho not only just appears the number of inbound contact.
-How can I make a call directly from Zoho CRM by using 3CX?
-is there away to answer the call from Zoho CRM?
Regards
Hello @mismail,
No, this functionality is not provided by the integration.
You need to use click to call with the 3CX Desktop App.
No, you need to use the 3CX clients for that.
Thank you for replay
Hassan Murasan
