101ms latency on sip trunk virtual environment
Riaan
Hi guys,
Doesn't matter on which Hypervisor(Hyperv 2016/Vmware all on different hardware aswell) we install 3cx 15.5 (Windows server 2012 R2) the sip trunk between 3cx and the sbc(freeswitch/asterisk) which resides on the same subnet and virtual switch stays on 101ms. From the SBC to the sip trunk over the Internet the latency is 2-3ms. We even tried 3cx v15.5 Debian aswell with the same results. If we install asterisk -> Sbc the latency is below 1ms between each other. I can safely say it isn't hardware related or hypervisor related (cause of the test between other pbx's). The vm specs are 4 cpu cores, 4gb memory. We even tried to decrease the cpu to only 1 core without success. Time is synced correctly. Tried legacy network adapter aswell. Did any of you experienced this before?
Any suggestions would be appreciated.
Any chance these are all Broadcom-based NICs?
Hi Cobaltit,
The NIC is an intel i210 gigabit network connection.
Dame24
