16.0.1078 Bug Report - MYPHONE_LINK_LOCAL_SEC
Tech-Advantage
I couldn't find out how to raise a bug report, but I'm posting here in the forum....
In the 3CX App provisioning XML file, the MyPhoneServerLocalSSLAddr key does not honor the hostname within MYPHONE_LINK_LOCAL_SEC parameter. Running latest version of 3CX. I believe this bug was introduced in a recent automatic update.
For example:
MYPHONE_LINK_LOCAL_SEC:
https://pbx.3cx.us:1234/myphone/MPWebService.asmx
3cxProv_XXXXX.3cxconfig:
<MyPhoneServerLocalSSLAddr>https://pbx.acme.com:1234/myphone/MPWebService.asmx</MyPhoneServerLocalSSLAddr>
Hi!
The Parameter MYPHONE_LINK_LOCAL_SEC is a global parameter. However the value that is put in the .3cxconfig file depends on what you select in the extension settings:
Could you check this drop-down the see if this matches the value in the ,3cxconfig file?
fransisco
