Solved 16.0 upgrade and remote phones
ScottLuc
Forum User
My auto update accidentally got turned on and auto upgraded to 16.0 before at least I was ready for it. Hope its a final version.
All is working fine but my yealink t46s phones at remote site are showing firmware not supported and wants 66.84.0.35 firmware. I cannot seem to do this via +firmware from 3cx to remote phones so my question is where is this file I can manually upgrade them?
I looked on yealink and they have up to version 66.84.0.15 but 3cx says I need version 66.84.0.35 where can I get this version for download and manual upgrade?
This will most likely be a 3CX specific file there is a download link in the below guide that 3CX keep updated normally for all Yealink phone models:
http://downloads-global.3cx.com/downloads/misc/phonefirmware/yealink/XX_83_00_55.zip
FYI this is the manual process you will need to follow: https://www.3cx.com/sip-phones/firmware-update-yealink/
If this version has not been released yet I think you should contact 3CX support and ask, alternately there maybe a folder on the server which may contain this FW file.
Super Awesome that worked, Thanks to all!
Reactions: YiannisH_3CX
GP Concepts
