2024 Version requirements for Free Version
kraichle
I'm running Version 18 Update 9 (build 20) 4 SC Free, but not sure if I need to upgrade to Version 20 before the first of the year or not.
I had the web banner displayed that my license will expire the first of the year, so did a little investigating and figured out the license didn't have the correct email. Once I corrected that the banner disappeared.
But, while i was doing the investigation i also saw some requirement that was saying that i had to be switched over to Version 20 by the first of the year too.
Is that correct?
Is that correct?
I can't say for sure, but I've mentions that v20 will be required in March, not January.
Ok, good. Things get kind of crazy around the holidays, so didn't want to have to worry about doing the v20 update at the same time. The update doesn't seem to be completely seamless and figured there'd be more time required to go to v20.
Thanks!
Senergia
