2N IP Verso VS 3CX
Mattie
Platinum Partner
I just bought a 2N IP Verso that i have to configure for my client. My Client has 2 doors that he wants to open with the 2N IP Verso. When his children push the code on the Verso, port A opens, when the house cleaner pushes an other code, door B should go open.
Is it possible to stream the video of the 2N Verso to the 3CX Mobile App when someone is at the door (Conversation)?
Thank you in advance.
Best regards
This would be something you configure on the device Web UI. There's no template for this one. You will need magnetic locks or similar to trigger the open with the 2N.
If the device is H264, no, but the Webclient and any desk videophone should work. The mobile app only supports VP8.
Reactions: Mattie
I have a Doorbird, which also uses h264. It does not work with any of the 3cx softphones (web, iOS). Audio works fine, but video will not start.
It's a pitty the h264 codec is not available on the iPhone, one of the main use cases for video is door intercoms.
The Webclient and Browser extension do support H264. If it's not working for you, then somewhere there's a misconfiguration. I have many GSC cameras from Grandstream and they are all SIP H264, and they work. Even over the SBC.
I can't imagen what the problem could be. Afaik there are no video-specific settings (for SIP) in the doorbird, and I can't find anything relevant in the 3CX admin section. Any ideas?
[email protected].
