3CX 10 Site Bridge
KhaledQuenawy
i have client with 6 Branch ... need 6 3CX server with 6License
what is the Scenario for connecting these 6 sites together as Bridge who will be master and who slave ,,, is Only one will be Master and others will be Slave or what ???
Why not one big cloud 3CX with SBCs on each site? One license, no bridge and easy configuration.
It really makes no difference which end is Master, and which is Slave, as each Bridge is independent from the others.
You have 6 sites, you have to decide how they are interconnected depending on calling patterns, trunk connections, etc. Do you do a star formation? One site with 5 bridge trunks, one to each of the other sites, or do you connect some of the other sites directly to each other as well. In the first senario, just to keep things straight, the 5 sites radiating from the (lets call it the) main site could be set-up as slaves to register to that site (master). But, it's up to you.
Because each site have voip gateway with different PSTN Line so i can't use SBC ( SBC for ip phones only ) and also can't use cloud because i don't have Static ip at all ... so i want to make every site isolated and can make outside call if any thing happen to the network and can't reach others
hughesdouglas
