3CX 15.5 & Mitel 3300 - Bridge
Liam Blom
Hi Guys,
I have connected a Mitel 3300 via a Master Bridge on the 3CX.
I can dial all extension on the Mitel from the 3CX and use the Mitel's SIP trunks to make public calls.
My only problem is when I try to phone from a Mitel extension to the 3CX.
I'm getting authorization errors:
Code:
31/05/2018 12:18:32:729 | 8 | [CM102001]: Authentication failed for AuthFail Recv Req INVITE from 172.27.65.2:5060 tid=3390417136-104690046 Call-ID=3390347136-104690042:
INVITE sip:[email protected]:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.27.65.2:5060;branch=z9hG4bK3390417136-104690046
Max-Forwards: 26
Contact: "Liam Blom" <sip:[email protected]:5060;transport=udp>
To: <sip:[email protected]>
From: "Liam Blom" <sip:[email protected]>;tag=0_3390347136-104690044
Call-ID: 3390347136-104690042
CSeq: 3 INVITE
Session-Expires: 240;Refresher=uas
Min-SE: 90
Allow: INVITE, BYE, CANCEL, ACK, INFO, PRACK, OPTIONS, SUBSCRIBE, NOTIFY, REFER, REGISTER, UPDATE
Proxy-Authorization: Digest username="10001",realm="3CXPhoneSystem",nonce="414d53595b0fcbf839:139a58995b7d15ebf9fa0062a7f74b91",uri="sip:[email protected]:5060",response="50d8f5e248fce0a6a49e0b712655c50e",algorithm=MD5
Supported: replaces, timer, from-change
User-Agent: Mitel-3300-ICP 14.0.0.95
Content-Length: 0
; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Level = 2
Severity = Warning
Tread = 8
Source = /home/repomaster/workspace/15.5SP4/SPBuild/Sources/Projects/PbxServer/src/Authorization.cpp, line:194
Could you share the settings that you used to connect the bridge? I'm trying to connect a Mitel system at a partner company to our 3CX. I've created the Master bridge and the tech on their side has created a SIP trunk. He's saying his trunk is UP UP but my bridge is showing down.
gmacinit
