Solved 3cx 4SC to 32SC hosted upgrade?
ahernandez
New User
I'm thinking I might go the hosted option on 3cx, its free for the 4SC, and would like to trial it before we commit and get the 32SC, anyone that has done a similar upgrade?
@ahernandez yes indeed it is free for the first year as for all our keys.
You may upgrade and test your key to 32 for a period of time and then you may purchase it.
When you will purchase the upgrade on the same key, we will automatically resize your machine to the correct specs.
Check here : https://www.3cx.com/ordering/pricing/hosted-info/
What trial period could I get for the 32SC?
If you need a good partner who doesn't requires you to be a ongoing client, DM me :) We can also help with getting the PoC for 45-days at the level you want.
Where are you located?
GP Concepts
