3cx and Civica CX Housing API
NDHIP
Probably something we could build relatively easily if it has an actual REST API, and not just SOAP.
thanks, not an expert on theses things, how can i tell>?
If the system only supports SOAP, it can be integrated too, however it will be much more work in that case as you need to build the XML to send and receive, and escape all that in the XML file of the template, so it's not very readable code, and very error prone. I would definitely go with a REST API if that's available.
ARKC
