3CX and Dynamics 365 Contact Creation
Amadeus49
In version 15.5, I am using the Dynamics 365 Server Side Integration. When I make an outbound call to a phone number that is associated with an account (and a contact with the account), I get two contacts created in 3CX. That makes sense because it is matching the phone number to the account and to the contact. Here are my questions:
  1. Is there a way to force it to use the CID of the account?
  2. Is there a way to force it to only create contacts for Dynamics 365 accounts and not contacts?
  3. How will this connection change with version 16?
Thank you for your assistance.
Hello @Amadeus49,
In v15.5 the integration doesn't have the ability to automatically create contacts. Are you sure you're using the server side approach?
Kind regards.
Yes, I was. I upgraded to v16 and that is fixed now.
costionofrei
