- Joined
- Sep 11, 2018
- Messages
- 8
- Reaction score
- 0
Hi all
Im trying my first CRM integration using the template generator and not getting very far!
The CRM is called JobAdder.
I have done everything that i think is correct, but im getting an error when im trying to authorize.
Error occured while accessing CRM. Please check log provided.
Started OAuthGetRefreshToken
Request text: https://id.jobadder.com/connect/token
Request form value code set to
Request form value grant_type set to authorization_code
Request form value client_id set to
Request form value client_secret set to
Request form value redirect_uri set to https://MYCOMPANY.3cx.co.uk/api/oauth2crm
Request form value state set to
Request form value scope set to read read_candidate read_contact read_company read_user
Response text: {"access_token":"xxxxxxxxxxxxxxxxxxxxxxxxxxxxx","expires_in":3600,"token_type":"Bearer","api":"https://eu1api.jobadder.com/v2/","instance":"eu1","account":3296}
Response finished
Finished OAuthGetRefreshToken
System.Exception: CRM call result is empty or null
at ManagementConsoleJS.Controllers.OAuth2CrmController.OAuth(String state, CrmProcessorFactoryDelegate crmProcessorFactory, IMemoryCache cache)
I have blanked out the url of the instance.
Can anyone help?
Chris
Response finished
Can anyone help?
Chris
