Simply DM me. And yes it's made to work with v18.what does it cost and what can it do? where can i find it?
works with the newst version v18?
Hi what are the modalities to integrate 3CX to Pipedrive, please. I will be interested in thisWe have an integration template.
I can't tell for sure as we didn't develop this integration, but this might be related to the caller's number not being matched to a CRM contact in this case. You might be able to solve it by applying Caller ID reformatting techniques.Additionally, only numbers in pipedrive CRM with a 1 prefix are journaling the activity in Pipedrive. Any number with a prefix not including 1, never show the journaling call activity in pipedrive. @weboptimizers
No, we don't support this CRM. This is the list of supported integrations:Does 3CX have a supported integration as of yet? I can look into the reformatting, that was my thought as well.
We have a template that we support and update frequently.why not? Can you please put this on your roadmap. pipdrive is big with over Used by over 100,000 companies in 179 countries. Thanks
You can up-vote for this idea:why not? Can you please put this on your roadmap. pipdrive is big with over Used by over 100,000 companies in 179 countries. Thanks
done! thxYou can up-vote for this idea:
https://www.3cx.com/community/threads/pipedrive-integration.57929/
ThanksThis worked for us, but I get a few errors im not sure how to handle. when testing any number in our CRM, I get this response: CRM Integration is working OK but contact number does not exist. Check log for more info or try a different number.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
