3CX Android green timer + media interaction issues + Bluetooth mode issues
Keyford
Hi, I have an issue with the android app, including safety concerns. But when I wrote my forum post it wasn't letting me post it due to being flagged as spam or inapropate. I'm not sure why, but I've attached what I originally wrote as a text document. Please see below, thank
@Keyford
We have released V18.1.3.129 Beta of the Android client today which should fix this issue:
https://www.3cx.com/blog/change-log/3cxphone-android-build-history/
You'd have to join the BETA program to get this update.
Just launch the Play Store, search for 3CX, and while in the Apps information page (where you see Uninstall & Open) scroll down to where it reads "Join the Beta" and press "Join".
It may take a few minutes but once complete you will see the Update button available for you to install the latest Beta app.
At any time, you may leave the Beta program by following the same steps to where the app information page reads 'You're a beta tester' and tap on 'Leave'
Should you still reproduce the issue, please let us know, together with your phone brand, model and Android version
@Keyford are you still reproducing the issue on the Beta build 18.1.3.129 mentioned above?
@Keyford
Thanks ThomB,
The issue of the green bar seems to be fixed. As for the Bluetooth issues. I haven't had many calls so I don't know if its still happening or not. I think I did get one call while listening to a podcast and it kept playing. But it seemed to go quieter, not louder which is a big improvement. I've only had it happen once though, so I'm not sure if that was a one off or not. I will let you know if I get any more data. Thanks
georgi
