3CX Apps Provisioning Failed
wei long
SOHO User
Hi 3CX expert, I have download 3CX Android apps and try scan QR code to provision the extension, but show QR provisioning failed.
Is there any configuration to do before scan the QR code?
What is your https port? Also from the mobile device are you able to reach the PBX FQDN?
Https port : 443
may i know how to check this
From your mobile simply open a browser and type the FQDN(https://fqdn), do you reach it?
The client needs to contact the PBX with the FQDN in order to provision. In this case you need to check your firewall.
You mean the server firewall?
It seems that the issue is with the PBX side firewall.
and dont forget to do the split DNS thing if you're connecting internally over wifi, saves going out then back in to the network
Senergia
