3CX Auto dialer where 3CX is hosted in Google
Cornel Antoche
Gold Partner
Hi There,
I need to find the best way to enable the auto-dialer (CFD) with my instance being hosted on Google Cloud.
Where should I put the database to get the number to call? Is anyone using this scenario?
Thank you
You can start with this: https://www.3cx.com/docs/cfd-creating-outbound-dialer/
Note that building a dialer in 3CX is not an easy task, that's why @VoIPTools have built their dialer tool over the years.
Also, we have our own dialer solution that works differently than most.
As you're self-hosted, CFD can be used without a problem as long as you have a Pro or Enterprise license.
Thanks for that
I did the dialler via CFD and I have a Pro license. My question is where should I have the database to get the number to call?
My 3CX instance is self-hosted on Google Cloud.
Thank you
Thanks for that
Thank you
Not on the 3CX that's for sure. The DB is up to you. You can use a file also or an API if you prefer. Usually, those DB would be either cloud or in your office's network.
VR46
