3cx Backup to anywhere
chidow
Why is it so hard to have 3cx backup to anywhere other than local?
onedrive?
PC?
google drive?
i dont want to pay a third party app to do this as medium mentions. I shouldnt have to.
Currently i manually log into each system and download a backup to my PC and then upload it to one drive.
Can i not do this automatically?
onedrive?
PC?
google drive?
Are you on a 3CX PBX Linux or Windows version?
linux at the moment. google cloud linux. thinking of changing to 3cx hosted if i can work out how.
Yes, good idea, consider StartUP cloud (max 20 users) or dedicated (< 21 users), it's simple, fast and above all they ensure high availability.
3CX manage your upgrades and backups !
Then your worries with backups location will be solved at the same time.
To begin, connect to your customer portal, you will find the management of your key, it will be offered to you, the steps are really simple !
Backup to a file and then use your own backup utility to save it anywhere you want. You need to commit to a robust backup strategy for more than just your 3CX server.
I would do this but it doesnt work.
If i click install and then hosted, it says its not available. "Subscription cannot be used for this install type"
I cant find anyway of fixing this without creating a whole new system.
how many extensions do you have in your phone system that you are trying to migrate?
FOLIT
