3CX Blue Screen On Install
StrangeWill
I'm having this issue on the 3cx Debian install, been debating using 3cx to replace our Asterisk system but after selecting a host name and a keyboard layout, I'm stuck at this.
It's a VM on vSphere v7.0.2, I've tried it on both my AMD and Intel cluster, I've tried downgrading the VM hardware to match v6.0 of ESXi, I've tried both the Debian 9 and Debian 10 3CX beta (we have a ton of Debian machines on our network today currently too). I'm kind of out of ideas on my side.
Not *really* a fan of deploying 3CX on Windows so trying to avoid that.
Edit:
I can "Ctrl + C" my way back to the previous prompt, so it's not frozen just presenting a prompt I can't see?
Edit 2:
Backing out twice and going to the main prompt list allows me to skip the rest of that step, maybe I'll be good?
Edit 3:
This left me with a non-functional keyboard and I couldn't complete the 3CX installation process.
Since you are on VMWare try changing the firmware to BIOS instead of UEFI.
When making the VM if you choose Debian 9 64 bit for the OS it should work without making any changes.
BIOS is the default for VMs when you select Debian 9 as the target OS. If I swap it to UEFI it won't even boot from the CDROM (doesn't detect bootable media)
homeit26
