3cx brigde hang up after a minute
Samuel43
hi,
we configure 2 3cx Systems via bridge. Everything works fine, we can see status from each phone and call via bridge , but after a minute the call will hang up. Any Idea ?
You should take a look at your logs and what you can find. Increase the logging level to verbose, then make a call between two extensions via your bridge (I'm assuming the calls that you say hang up are between extensions). Check the log after the call drops
florentrobineau
