- Joined
- May 10, 2019
- Messages
- 8
- Reaction score
- 1
I'm trying to connect to 3CX API (config server) outside 3CX and I'm able to do it with SSH tunnelling, but I have a problem with events.
Using the same dotnet application, when I connect to config server and start listen to events on local machine (connecting to 127.0.0.1) I'm getting all events that I need.
Using the same dotnet application, when I connect to config server and start listen to events from remote machine (connecting via SSH tunnel) I'm getting only some events.
PhoneSystem.Root.Inserted += new NotificationEventHandler(Root_Inserted);
PhoneSystem.Root.Updated += new NotificationEventHandler(Root_Inserted);
PhoneSystem.Root.Deleted += new NotificationEventHandler(Root_Deleted);
Aplication run on localhost:
Coś sie dzieje... REGISTRATION
Coś sie dzieje... REGISTRAR
Coś sie dzieje... TRUNKREGTIMES
Coś sie dzieje... CONNECTION
Aplication run on remote machine using SSH tunnelling:
Coś sie dzieje... TRANSACTION
Coś sie dzieje... DN
Coś umiera... TRANSACTION
I'm not getting REGISTRAR, CONNECTION and probably many more events from remote machine
Firewall (iptables) is disabled. I know this is not secure configuration but this VM is only for testing.
Do you have any ideas why events are limited from remote location?
Thank You.
Thank You.
