3CX CallFlowApp-Gallery - A public place to share and discuss CallFlowApps
9Chris6
It would be great if this forum had a place to publicly share and download CFD projects. I see far too many people that demand features which are possible to solve with a few lines of C# code in a CallFlowApp.
Please 3CX Mods, make this possible and open up a new category or something!
3CX is such a good piece of software, let your community make it even better!
There's a Call Flow Designer forum specially for that.
Reactions: 9Chris6
The Call Flow Designer forum is ok, but it would be better if there would be a dedicated category for posting your own CallFlowApps with a small description of what it does and how it works. With the rule that you are only allowed to post a more or less finished CallFlowApp project .zip with a description and a fitting title.
The app can then can be further discussed in the thread.
Don't you think that would be nice?.
Not sure I'd want to run random public code myself.
If you don't review the code before you run it,it's your own fault if something goes wrong.
It is not like that this is not already a thing for e.g. PowerShell with the PowerShell-Gallery.
People share PowerShell Commandlets and rate them, comment on them etc. there is always a risk involved, but i don't think that that means it should not be done.
There are so much possibilities with the CFD that are just overlooked or not known - maybe because the CallFlowAPI is not officialy supported and not really publicly available - but i nevertheless think this would be a good idea for advanced users to explore possibilities and get more advanced and customized solutions to their customers or just share how they implemented certain stuff.
fransisco
