3CX calls dropping 29:30
SpaceCowboy
I have been troubleshooting an issue of come calls dropping at 29:30.
The SIP provider has narrowed it down to re-invite happening around this time, coming from 3CX.
I've checked over the Codecs where it looked to be all correct.
I also noticed "Supports Re-Invite" is enabled, maybe this is causing the issue?
Attached the pcap and explanation from the SIP provider.
Any help would be grateful!
Why do you have re-invites enabled on your trunk?
Is this a 3CX Supported provider?
It has been a long time since I have seen this problem, but some firewalls force a renegotiation of ports on a scheduled basis. Given that this happens at the same time (every 30 minutes), this seems like a scheduled renegotiation either by your firewall or your SIP provider.
Reactions: jed
Jake_Southern
