3CX CDR Shows UTC timing in PMS log
Steven.Zhang
Platinum Partner
We are using 3CX Linux 15.5 SP6. When 3CX send the CDR message to PMS it shows in UTC timing. 3CX timing is correct as i tested from linux date command. Is there way to correct this timing ?
at current this is the way and the PMS needs to make an offset to it, we are aware that some PMS cannot do so and consider for the future to alter the behaviour.
K7oR0x
