Solved 3CX CID
Xeron
Trainee Partner
Hi Team
Before I spend hours trying this out, can someone tell me if its possible and maybe leave a few tips.
I have moved a Client from Telstra to a recommended SIP provider, however when I organised a Number diversion to 3CX I discovered that the 100 Number range Indial and 2 fax numbers were all together so if you divert one you divert the lot. The Indial no prob, however the fax numbers just come to the main receptionist which annoys them by the faz squeal and retrys.
My question
As they only really receive faxes from 3 numbers, can I just setup a 3CX Fax Server with one of my SIP DIDs, then create a CID Rule so when it sees one of the 3 Fax numbers it will just forward them as an email to a Mailbox instead of sqealing in the Receptionists ears
Any help will be greatly appreciated
Ill answer my own post for anyone that needs to know.
Yes CID Rules are great, all my problems are sorted. 3CX is a Great system :)
mazet
