3cx Client Plugin Design and Language
Steve G.
is there a way to get the current theme and language of the Windows phone Client so that we can adapt the UI of the Plugin accordingly?
Also it will be valuable if the current Hotkey configuration could be fetched.
I did not see any suitable Methods in the MyPhonePlugins class.
Thank you, best regards
Steve
Hello @Steve G.
Please check the file "C:\Users\USER_NAME\AppData\Roaming\3CXPhone for Windows\3CXPhone.xml", there you will find the 3CXPhone configuration.
The application theme is in General > ApplicationTheme.
Hot keys are under General > Hotkeys.
Kind regards.
costionofrei
