3CX Cloud Setup not working with MyNetFone.
jaime124
Hi All,
My organisation is switching from a Kerio box PBX (on premesis) to 3CX hosted on Azure. I have created an instance of 3CX in Azure and this seems to be working fine. Inbound and internal calls are working fine but outbound calls to external numbers are failing. I have never set up a virtual PBX before so am unsure where I have gone wrong. I have added our SIP provider details in 3CX and followed the guide for setting up the SIP Trunk in 3CX. However I'm still unable to make outbound calls. I have created outbound rules that should enable outbound calls but I still seem to be missing something. Can you please point me in the right direction?
I have a pdf from our SIP provider (MyNetFone) showing what our packets should look like. An actual log from a call is attached. I believe there is something wrong with the IP our PBX is sending to the SIP provider. However I have already added our public IP into the contact field.
Has anyone else had this issue when configuring 3CX for MyNetFone and found a resolution?
Thank you.
I did. I have also reached out to them but haven't had a response as yet. I note that my logs look different to their document so I think maybe this setup document doesn't work for this provider?
Also inbound calls and calls between extensions work fine. It's just outbound that won't work.
bosdorf
