3CX Cloud -
tmichaelis
SOHO User
Hi everyone,
I’m having an issue with incoming DID routing on a 3CX SMB Cloud installation.
System:
  • Edition: SMB
  • Version: 20.0.995 SP9
  • Deployment: Hosted by 3CX
  • License: Free
  • SIP provider: Easybell
Problem:
The DID I want to route is:
+49 7171 95XXXX24
However, when I call this number, the call is not routed to the destination configured for this DID. Instead, it ends up at the default/main trunk destination, which in my case is the ring group 23661 (Eisenmedia).
At first I suspected that the final digits 24 were being removed somewhere, but the SIP Trunk Checker shows that Easybell is actually sending the complete number.
Relevant parts of the log:
inbound_did = 49717195XXXX24
inbound_did_rule =
The SIP INVITE also contains the complete DID:
INVITE sip:49717195XXXX24@...
To: <sip:[email protected]>
Later in the routing process, 3CX sends the call to:
Wringgroup: 23661
public_push_callername = 01XXXXXXXXX:RG: Eisenmedia
So as far as I can tell:
  • Easybell sends the full DID correctly.
  • The DID is not being truncated by the provider.
  • The full DID is configured on the SIP trunk.
  • inbound_did_rule remains empty.
  • 3CX therefore appears not to match a specific DID rule and falls back to the trunk’s default destination.
One additional complication is that in the SMB/Cloud edition there is no editable “Inbound Rules” section like there is in some other 3CX setups. The “Inbound Rules” entry under Reports is only a report.
I have already checked the DID under Admin → SIP Trunks and it appears to be entered completely.
Has anyone seen this behaviour on 3CX SMB Cloud?
In particular, I’m trying to understand:
  1. Why does inbound_did_rule remain empty even though the received DID matches the number configured on the trunk?
  2. Does the DID need to be entered specifically as 49717195XXXX24, +49717195XXXX24, or in another format for SMB Cloud?
  3. Is there another place in the SMB edition where the DID-to-destination assignment needs to be configured?
  4. Could this be a limitation or issue with DID routing on the Free SMB license?
Any pointers would be appreciated.
Thanks!
In 3CX V20, Inbound Rules are no longer available.
The important point is that inbound calls are working, even though they are currently being routed to a different extension within the system. Please verify that the DID is assigned directly to the correct extension and that the same DID is not assigned to the SIP trunk’s default destination.
You can also use the Inbound Rules report to review the current routing configuration and identify where the DID is being directed.
