3cx consultant?
easyasABC
Forum User
morning all!
not sure if this is improper, but i am in need of an ongoing relationship with a third party consultant for our 3cx deployment. we are in a highly regulated industry in the USA and need an ongoing relationship with a 3cx specialist that can help us setup our 3cx for maximum efficiency and compliance controls. some of my needs are simple, while some are complex and likely will require integration with other 3cx third party solutions like VOIPtools (which i have already purchase). just need someone i can trust to help keep our platform running smooth and integrated appropriately (crm integration, call flow, etc). if this is disallowed in forums, please advise. thanks!
morning all!
not sure if this is improper, but i am in need of an ongoing relationship with a third party consultant for our 3cx deployment. we are in a highly regulated industry and need an ongoing relationship with a 3cx specialist that can help us setup our 3cx for maximum efficiency and compliance controls. some of my needs are simple, while some are complex and likely will require integration with other 3cx third party solutions like VOIPtools (which i have already purchase). just need someone i can trust to help keep our platform running smooth and integrated appropriately (crm integration, call flow, etc). if this is disallowed in forums, please advise. thanks!
Where are you from? If Canada/US, we might be able to help you.
We are in Florida. Thanks!
Do you need someone close to Florida? And what type of industry are you in to expect that many regulations and compliance setup?
not sure it would need someone close. most would be remote support. we have IT for hardware concerns and physical deployment. industry is financial services/banking
I see. May I recommend @BrenttG ? He has lots of experience with secure systems.
Have you tried this page?
https://www.3cx.com/ordering/find-reseller/
While not required, it may not be a bad idea to find someone local. Otherwise there's a number of partners on the forums here, and I believe @voiptoys does consulting and if a lot of what you do hinges on their addons might be the best choice.
bosdorf
