3CX Debian OS Update Failed - v18
ghernandez
Intermediate Cert.
I'm having this error upgrading my 3CX AWS hosted instance. We haven't made any changes to OS ever but we get the following error log.
Any advice?
Thanks in advance
You can try following the instructions in the file (You might want to run 'apt --fix-broken install' to correct these.) or you can backup and restore to a new VM.
Just make sure that , if the issue persists even after running
you check the log again to see if it is the exact same error or something different.
fngl
