Solved 3CX does not recieve call through SPA-3102
armello
Hi, I know that the SPA-3102 is not officialy supported to operating with 3CX however it is working fine to make call but for some reason i cant recieve. The extention does not ring when I try to call to the analog line. please check the imagens. thanks!
Does the 3102 appear to registered in 3CX and in the Info tab of the 3102?
Do you see a log in the 3CX Activity Logs for an incoming call? Error message?
Is the 3102, perhaps, set to send incoming calls to the FXS port?
If you still have issues, please post the entire PSTN tab with the Advanced (upper right corner) option selected
Hi leejor, thanks for the help!
- Its apear registred in both sides.
- i see no error messages
- i am not sure if it is set to send incoming calls to the FXS port. Don´t see this option.
OK, here are some changes to make, all in the PSTN Tab, from top to bottom...
Proxy and registration
Use OB proxy in Dialogue = No not needed, there is none anyway
make call without registration = No device should always register or there is a problem
Audio Configuration
Preferred Codec = G711 if you use audio DTMF over the trunk, you don't want it forced use a low bit-rate codec
Dial plans
Dial Plan 8 = (S0<:10000>) that's a zero after the S
PSTN to VoIP gateway setup
PSTN ring Thru Line 1 = No set to yes sends incoming PSTN calls to the phone in FXS
PSTN CID for VoIP CID = Yes
PSTN caller Default DP = 8 refers to the dialplan above
FXO timer values
PSTN Answer Delay = 3 if you use Bellcore CID then this delay allows it to be captured
Can't see anything else off-hand, so see if that works for you
Reactions: armello
Thank you very much leejor!! I think the main problem was the "PSTN ring Thru Line 1 = No set to yes sends incoming PSTN calls to the phone in FXS"
Well, that was part of it. It is one of the options that splits the FXS and FXO. However, without the proper dialplan, incoming calls would not "forward" to the trunk number that you created, in 3CX.
Bluebox Global
