3CX failed to establish a TCP connection to activate.3cx.com.
olivierdelvaux
My server is not able to communicate with to activate.3cx.com.
But I can ping it from the console. My primary dns is 8.8.8.8
I have renewed my licence, but I can't update the status on my server.
Any idea?
Thanks for help.
BR.
You're out of date. You need to upgrade to U5, which in this case will be impossible now that you are outdated.
Full backup, reinstall using ISO/wizard, restore backup.
I can't use online update?
I was able to update my other sites using old V18 this morning
Hi @olivierdelvaux
Since there are no updates available in the Management Console, the only option is to take a full backup, download the latest 3cx ISO from portal.3cx.com, redeploy to a new machine using the latest 3cx iso, and restore the backup.
indeed....
Just tried to restore a 800mo backup 18u2 to a 18u6 test version and it didn't worked.
I got disconnected from console and nothing happened.
How Can I make sure my backup is complete before reinstalling my server?
indeed....
unofficialy adding myself to the same crap on mine list....guess we should start looking at freepbx....this f this bs
What platform are you running 3CX on?
It's running on debian, on premise VMware virtual machine
It's now restored and working.
Thanks for help.
GCLANtech
