3CX Fax Server
racostamnet
New User
Hi, fairly new to 3CX, still learning everything before I start working on it. Was taking a look at the Fax Server options and features and noticed theres no way to send faxes just receive them? Can anyone confirm this? Did a quick google search but only found forum posts from back in 2015.
If so, what options I have? Anything else I can do that dont require physical equipment?
Thanks in advance!
E-FAX
we use Ferrari Fax Server with 3cx without any problems. It is a nice product and it runs as VM
https://www.ferrari-electronic.de/produkte/officemaster-suite.html
Unfortunately 3cx Fax is not Configurable enough for the most Fax scenarios. (T.38 Yes No, Bautrates and so on)
We have connected it to 3cx with Bridge Mode
kind regards
We recommend to customers they stop using faxes anyway, and in some cases the ability to receive faxes only is sufficient, so the customer can follow up with the person/company sending the faxes and respond a more modern way. So the 3CX fax server is very useful in these cases.
WinSip
