3CX free/trial confusion
ade111
SMB User
Under My Systems, if I click Upgrade, the popup shows that the subscription expires in 56 days, do I need to do something to ensure it continues running?
I previously had a 3CX cloud free system and it appears it was shut down, I didn't receive any warning emails or anything it just no longer displayed in My Systems and could no longer be logged in to
With the free offering, you must log in frequently to prevent your system being deleted. Keep ensuring you log in to your admin and your system should keep running.
Its not frequently, its once every 90 days... Login to the web client or make sure you have an app which you startup at least once every 90 days.
If you have a system with only IP phones its best to use the multi tenant edition of a partner......
lonedigger
