3CX Google Installation Server Error
dserel
I have a 3cx installed on a google cloud. I had not logged in for 1 month and i tried to login today and I got a server error message on the https://webflowpc.3cx.gr/#/login screen.
Any ideas where I should start searching?
Hello @dserel
Are you using the 3CX 1 year free hosting?
As far as i can see the PBX is installed on your own Google instance so you should have access to the OS. Using SSH check if all 3CX services are running. From the error you are getting when trying t log in i would suspect the management console service.
WagnerFT
