3CX ICOs and recommendation
Aius Locutius
Hello
I see a lot panic so i hope this ICO will help you, please be patient and wait for more information from 3cx
This ICO will help to define if you have install the corrupted version
Corrupted version
Windows: 18.12.407 and 18.12.416 for
MacOS : 18.11.1213
Recommandation :
Uninstall the produit with control panel on windows or see the script posted above
Use the PWA version
For installing the APP you need to use Edge Chromium or Google Chrome
Check the documentation here : https://www.3cx.com/blog/releases/web-client-pwa/
Script for helping you
Bash :
# Disable 3CX Unattended-Upgrades Service
systemctl stop unattended-upgrades
# Collect the version of 3CX Desktop Apps on the Server
cd /var/lib/3cxpbx/Instance1/Data/Http/electron
ls -la * > /root/3cx-desktop-versions.log
# Remove the files
rm -rf /var/lib/3cxpbx/Instance1/Data/Http/electron/osx/*.dmg
rm -rf /var/lib/3cxpbx/Instance1/Data/Http/electron/osx/*.zip
rm -rf /var/lib/3cxpbx/Instance1/Data/Http/electron/windows/*.msi
rm -rf /var/lib/3cxpbx/Instance1/Data/Http/electron/windows/*.nupkg
PowerShell :
$softwareName = "3CX Desktop App" # Replace with the name of the software you want to check
$version = "18.12.416.0" # Replace with the version number of the software you want to check
$installedSoftware = Get-WmiObject -Class Win32_Product | Where-Object {$_.Name -eq $softwareName -and $_.Version -eq $version}
if ($installedSoftware) {
Write-Host "True"
} else {
Write-Host "False"
SHA256Operating SystemInstaller SHA256FileNameVirus Total
dde03348075512796241389dfea5560c20a3d2a2eac95c894e7bbed5e85a0accWindowsaa124a4b4df12b34e74ee7f6c683b2ebec4ce9a8edcf9be345823b4fdcf5d8683cxdesktopapp-18.12.407.msiVirus Total Link
fad482ded2e25ce9e1dd3d3ecc3227af714bdfbbde04347dbc1b21d6a3670405Windows59e1edf4d82fae4978e97512b0331b7eb21dd4b838b850ba46794d9c7a2c09833cxdesktopapp-18.12.416.msiVirus Total Link
11be1803e2e307b647a8a7e02d128335c448ff741bf06bf52b332e0bbf423b03Windowsd3dcompiler_47.dllVirus Total Link
7986bbaee8940da11ce089383521ab420c443ab7b15ed42aed91fd31ce833896Windowsffmpeg.dllVirus Total Link
92005051ae314d61074ed94a52e76b1c3e21e7f0e8c1d1fdd497a006ce45fa61macOS5407cda7d3a75e7b1e030b1f33337a56f293578ffa8b3ae19c671051ed3142903CXDesktopApp-18.11.1213.dmgVirus Total Link
b86c695822013483fa4e2dfdf712c5ee777d7b99cbad8c2fa2274b133481eadbmacOSe6bbc33815b9f20b0cf832d7401dd893fbc467c800728b5891336706da0dbcec3cxdesktopapp-latest.dmgVirus Total Link
Other ICOs
Domain nameStringEmail
akamaicontainer[.]com(Base64) $KQAAAKg+dTjCD1DLped3aAe8CookwQWzhaбsxQrtzFo3oPSeis4u0W+4SML2v0u+AMgvjGSHFffy4wmikaas64EHqK9161fil/ZtsXN3hBAZac9JzxGG2dtyPWMMSVxiWkg7HgVfpCU=cliego.garcia@proton[.]me
akamaitechcloudservices[.]comphilip.je@proton[.]me
azuredeploystore[.]com
azureonlinecloud[.]com
azureonlinestorage[.]com
dunamistrd[.]com
glcloudservice[.]com
journalide[.]org
msedgepackageinfo[.]com
msstorageazure[.]com
msstorageboxes[.]com
officeaddons[.]com
officestoragebox[.]com
pbxcloudeservices[.]com
pbxphonenetwork[.]com
pbxsources[.]com
qwepoi123098[.]com
sbmsa[.]wiki
sourceslabs[.]com
visualstudiofactory[.]com
zacharryblogs[.]com
github[.]com/IconStorages/images
fngl
