3cx Installation
AndreasMetal said:
Argh :evil:
I have download all the latest important and no important updates, I change the location but nothing seems to works :cry:
My last suggestion is to manually remove the 3CX installation. Remove the directory and all register keys of 3CX. Reboot your computer and try the installation again. If that doesn't work you should consider reinstalling your Windows.
It doesn't works anything.
Can anyone member of the stuff of 3cx send me the old installer with the version 5.1? If yes take this email: info [at] oasisdesign [dot]gr and send.
Thanks ;)
just download the latest one and before install remove all 3CX stuff
I tried this.
I have clear and the littlest file, but it it is not works :(
Try to remove it in safe-mode. It meigh be the problem.
I have the same problem too, at the end of the whole installation it says:
There is a problem with this Windows installer package.
A script require for this install to complete could not be run.
Contact your support personnel or package vendor.
I can klick an OK button and that's it.
Next thing: It rollsback the install automatically.
No error number or better indication whats wrong or could be done.
I updated windows installer manually from http://www.microsoft.com
Same result, same errormessage.
I download and run the file directly from 3cx.com, but that doesn't help too.
In a different posting about the same subject I heared Nick Galea say that it only starts from Vista business or XP pro.
So home or premium editions from windows are not good enough to work with 3CX. Maybe that's the problem.
Yes :evil:
And it's a little bit important...then..
After downloading the 3CX installer, right click the file and click "run as Administrator"
That should fix it.
yes, vista needs almost for everything to run as administrator
cheers
You are a star :shock: 8) 8) 8) :roll: :roll: :roll:
Pleasure
I had the same problem. I had to uninstall the VOIP client as well, then as there is no "Run as administrator" option for MSI packages, had to run a CMD prompt as admin, then run the MSI from there. Finally it's installed. PS: Had no problem installing the last version from the .exe file so maybe have both???
SaschaA_
