3CX Instance lost 365 Integration
LyonAdmiral
SMB User
Our 3CX instance in the cloud is integrated with Microsoft 365; we set it to use our Microsoft accounts for administration and of course end users. Yesterday it was working, I was in the management console to work on some FXS adds and today, the Microsoft button disappeared from both management and end user extension login pages. That shouldn't just happen on its own, correct?
Are you logging in as the admin user , in the top right can you see an uppercase A
I can't get in because I don't recall what the local admin & password was set for when I set it up, I acknowledge that is my problem.
One of the things I'm trying to do is to restore from a backup using the Linux command line:
sudo -u phonesystem 3CXRestoreCmd --file=/var/lib/3cxpbx/Instance1/Data/Backups/3CXScheduledBackup.1.zip
But when I run that command I get the result back that the password provided is not valid; I'm assuming it is because I encrypted backups but I thought I was using the correct password.
StevenWillems
