3CX Integration To SharePoint
techies
Hi there we have a client who consistently use the call recordings option.
The call recordings have now filled up and they are unable to record any calls. I gave them the option that we could store their recordings on Sharepoint.
I ran the integration to Sharepoint and it shows it has run. However, when we try choosing a folder to store the recordings in. Its blank and there's no folders?
The version they are using is V20
Note that 3CX uses the default sharepoint site <domain>.sharepoint.com.
You will need to create a folder in the documents site in here and there it will create relevant folders with what you've named them as under Storage page.
arming
