3CX Integration with iFax (HylaFAX)
amir_
We are hoping to migrate away from the obscene complexity and cost of Cisco IPT. We rely heavily on faxing. Currently, we route faxes as follows:
FAXING PARTY >>> PSTN>>>>FLOWROUTE>>>>CISCO CUBE>>>>CUCM>>>>HYLAFAX VM>>>>>KONICA MINOLTA MFP
Can we do the following where 3CX simply acts as a pass through ?
FAXING PARTY >>> PSTN>>>>FLOWROUTE>>>>3CX>>>>HYLAFAX VM>>>>>KONICA MINOLTA MFP
We do not want to leverage the native INBOUND fax server within 3CX. We have all of our faxing dialed in via HylaFAX and are VERY happy with that solution as we have nearly a million pages per year.
TIA
If you are asking if 3CX speaks SIP, the answer is yes. It is also standards compliant. Everything else is up to you to test. It's been a long time since I've done anything with Hylafax but I thought there were softmodems that spoke SIP you could run on the hylafax box that would talk directly to flowroute
[email protected].
