3CX IOS and Android App still receive notifications when Do not Disturb is active
HospiceAdmin
Trial User
Hello, testing out 3CX Hosted for one month.
Added a few users with the 3CX Mobile app.
when users set their status to Do not Disturb, they don't receive notifications from incoming calls, but do still receive notifications on incoming internal private + group chats.
is this by design? or is this configurable somewhere in the settings?
if not, what is the best way to turn off notifications when in status is set to not disturb?
Thanks in advance!
Hello HsopeciAdmin,
You can navigate to the call forwarding options of the extensions and disable the option
Accept PUSH notification for the Away and Do Not Disturb status.
When you disable this option, you will not receive notifications on the mobile app.
Thanks! That was the setting I was looking for!
Reactions: KyriacosS_3CX
arming
